Online course Dialux EVO 9.2 – Basic
195,00 €
Register
Objectives:
Throughout this course you learn how to work with Dialux EVO a software program which is being used for lighting calculations. After completing this course, you can use the program and handle projects from start to finish. We will cover topics like importing files from other (CAD) software, show you how to build optimal visualizations and learn producing high-quality reports.
Why this course?
Within the lighting design process there are many situations when there is a need to provide insights about the intended end results. By expanding your knowledge of the EVO you will be able to show a better motivated proposal. With this software you can present your ideas to your client both the technical part as well the esthetical aspects of your design. With a thorough knowledge of the software you will enhance your professional appearance towards your client and your commercial opportunities will grow.
Content
Topics
- user interface
- settings
- drawing a space
- CAD import
- cases interieur and exterior
- using objects
- selecting luminaires
- applying light sources
- lighting calculations from A to Z
- working with colors
- how to apply to norms and regulations
- light scenes
- materials and textures
- setting up client reports
- tips and more
Information
- lessons online
- ask questions through email
- feedback on homework
- certificate after completion
Trainers
Berry van Egten
Berry van Egten
lighting designer + lighting educator
Lighting Design Academy www.lightingdesignacademy.org
  • Berry van Egten
    Professional expertise:
    • Msc Lighting Design
    • IALD MSLL MIES ELE LR
    • European Lighting Expert
    • Hogere Verlichtingskunde
    • (more on my LinkedIn profile)
    Work experience:
    Working with light and lighting as an independent architectural lighting designer. Strongly involved and active within several international lighting associations.
    Current occupation:
    • Lighting Designer
    • Lighting Educator
    • Course Developer
    • Certified Dialux EVO trainer
    Read more >
Other events
Detected timezone
