Expert for Lighting Design
2 499,00 €
25. - 29.05.2020
Register
Our seminar focuses on light. You learn to analyse architecture, to consider the utilization of the space and human needs and to design optimal lighting. You work on realistic projects with pen and paper. In our own laboratory you will experience the effectiveness and effect of light yourself. We train you for all stages from the concept to the presentation and implementation. Since we are free of obligation to any manufacturer, questions about products and trends are answered honestly with no holds barred. After the seminar you are ready to work at once as a modern expert for lighting design.
FORMAT
Seminar
DURATION
5 days
METHOD
You can experience and try out a lot live: The seminar includes live demonstrations, workshops and theory.
REQUIREMENTS
Basic knowledge of lighting technology required.
TARGET GROUP
Interior designers, lighting designers and all those interested in qualitative lighting design.
CERTIFICATE
DIAL certificate as »Expert for Lighting Design«.
Details
DIAL GmbH
DIAL GmbH
Bahnhofsallee 18
58507 Lüdenscheid NRW
Germany
Content
DAY 1
  • Daylight as the basis for planning artificial light
  • Process of lighting design
  • Working with architectural plans
  • Project analysis: lighting requirements
  • Terminology to describe the qualities of light
DAY 2
  • Creating lighting concepts
  • Selection of lamps
  • Light and material, colour rendering
  • Overview of different lighting strategies
  • Strategy: direct lighting, general and accent lighting
DAY 3
  • Indirect lighting, general and accent lighting
  • Direct/indirect lighting
  • Wall lighting, wall washers, accent lighting, grazing
DAY 4
  • Scallops
  • Complementary strategies
  • Integrating strategies into an overall concept
  • Selection of luminaires, grouping and dimensioning
  • Presentation of the overall plan
DAY 5
  • Design of a complete and real complex object as consolidation
  • Presentation of results
  • Closing discussion
Trainer
Trainer for the seminar
Ariane Ignazak
Ariane Ignazak
Trainer & Lighting Designer, Team Lighting
Dipl. – Ing. Innenarchitektur
DIAL GmbH
  • Ariane Ignazak
    Fachliche Expertise
    Ariane Ignazak studierte Innenarchitektur an der Hochschule Ostwestfalen – Lippe mit dem Abschluss Dipl.-Ing. (FH). Nach dem Studium sammelte Frau Ignazak in Deutschland und der Schweiz zahlreiche Erfahrungen im Bereich Lichtplanung und -projektierung, die sie seit 2015 als Trainerin bei DIAL mit viel Engagement und Freude an unsere Seminarteilnehmer weitergibt.
    Aktuelle Tätigkeit
    • Trainerin für lichttechnische Seminare, Webinare und Workshops im In- und Ausland
    • Durchführung der Dialux Evo Software-Schulungen im In- und Ausland
    • Lichtplanung von anspruchsvollen Innen- und Außenraumprojekten
    • Seminarentwicklung, Vorträge, Gutachten, Kundenberatung…
    • Unterstützung bei der Weiterentwicklung von DIALux evo, durch planerisches Wissen und konstruktives Feedback aus den Seminaren
    Statement
    „Schon während meines Studiums habe ich einen ersten Einblick in den Bereich Licht erhalten und bin seitdem fasziniert. Es ist schön ein breites Spektrum an Aufgaben in diesem Bereich selbstständig zu bearbeiten. Die Zusammenarbeit und der Gedankenaustausch mit engagierten Kollegen und Kunden bereichern meinen Alltag. Es macht Spaß, sich stetig weiterzuentwickeln und diese Erfahrungen mit anderen zu teilen.“ Ariane Ignazak
    Read more >
Cornelia Wuttke
Cornelia Wuttke
Dipl. – Ing. Architektur
DIAL GmbH
  • Cornelia Wuttke
    Fachliche Expertise
    Cornelia Wuttke studierte Architektur an der Bauhaus Universität in Weimar mit dem Abschluss Dipl.-Ing. Außerdem absolvierte sie ein Weiterbildungsstudium in Lichtanwendung an der Technischen Universität in Ilmenau. Danach war Frau Wuttke als Lichtplanerin in Berlin und Sydney tätig. Seit 2008 ist sie bei DIAL angestellt und vermittelt unseren Seminarteilnehmern mit Begeisterung ihre fundierten Kenntnisse.
    Aktuelle Tätigkeit
    • Durchführung von photometrischen und colorimetrischen Messungen im akkreditierten Lichtmesslabor
    Statement
    „Es war meine Begeisterung für Fotografie, Architektur und Licht, die mich zu DIAL führte. Im Team Lighting kann ich alle meine Interessen kombinieren, erweitern und mit anderen teilen.“
    Cornelia Wuttke
    Read more >
Klaus Bieckmann
Klaus Bieckmann
Team Leader Lighting Design & Technology
DIAL GmbH
  • Klaus Bieckmann
    Fachliche Expertise
    Klaus Bieckmann studierte Innenarchitektur an der Hochschule Ostwestfalen – Lippe mit dem Abschluss Dipl.-Ing. (FH). Nach dem Studium arbeitete Herr Bieckmann bei einem Leuchtenhersteller im Bereich Vertrieb und Projektierung. Im Jahre 2006 erfolgte der Wechsel zu DIAL. Seitdem gibt er sein Wissen mit Begeisterung an die Seminarteilnehmer weiter. Seit 2015 ist Herr Bieckmann Teamleiter des Teams Lighting Design & Technology, dem auch das akkreditierte Lichtmesslabor angehört. Herr Bieckmann verfügt über langjährige Erfahrung im Bereich Fortbildung, Lichtplanung, Gutachten sowie Consulting und ist Autor zahlreicher Fachartikel.
    Aktuelle Tätigkeit
    • Planung und Durchführung von Seminaren und Workshops im In- und Ausland
    • Planung und Entwicklung von E-Learning Produkten
    • Konzipierung und Abwicklung von Lichtplanungen im Innen- und Außenbereich
    • Beratertätigkeit
    • Gutachtertätigkeit
    • Fachvorträge auf verschiedenen Veranstaltungen (Licht 2016 Karlsruhe, Luxeuropa 2017 Ljubliana, Dortmunder Lichttag 2019, u. a.)
    • Organisation und Coaching des Teams Lighting Design & Technology
    Statement
    Licht ist eine entscheidende – leider oft unterschätzte – Komponente in der Architektur. Allein über die Beleuchtung lassen sich Stimmungen im Raum verändern und Emotionen wecken. Ich sehe es als meine Aufgabe an, dieses Bewusstsein auch bei anderen Menschen zu wecken und mit einer guten Lichtplanung Lebensqualität zu schaffen.
    Read more >
Your Contact
Irina Schäfer
Irina Schäfer
+49 2351 5674 407
weiterbildung@dial.de
DIAL GmbH
Other events
